NI TestStand Idea Exchange
kent.wedeking
Improved TestStand Deployment Utility CLI
Status: Already Implemented
As NI Package Builder evolves to be the future way of creating TestStand deployments, we'll add a well documented CLI for it.
In the meantime, for your ask on reading back build status, BuildTSD does return exit codes (Refer here)
There is rudimentary Command Line Interface (CLI) integration in the TestStand Deployment utility.  Its undocumented, and is one flag.  "build".  Which is useful, but the fact that my only option to determine if the build succeeded is manually parse the build output log is cumbersome and error prone.
In a world where continuous automation and build automation are becoming daily buzzwords, additions to the CLI are sorely missing.
I don't necessarily need to be able to do much from the CLI, but having control and the ability to read back status on a build would be tremendous.
https://forums.ni.com/t5/NI-TestStand/Running-the-deployment-utility-from-the-command-line/td-p/1624...
2 Comments
HarshaBhushan
Status changed to: Under Consideration
HarshaBhushan
Status changed to: Already Implemented
