Problem description:
The parameters out of the step settings window and the called subsequence are not linked. If you delete any parameter out of the middle of the parameter list and the calling sequence use the "default" flag for this parameter(s), this default flag(s) will be shifted to the next parameter in the list and the original value will be overwritten. To reproduce this issue:
You can see that the name of parameters you have deleted in the subsequence disappear, but the "default" flag(s) are shifted to the parameters 5+6 and the previous configured values were overwritten. If you delete any parameter that is configured without the default flag the deletion works fine.
Problem: If you want to delete a parameter that is used in many subsequences by searching for it and delete it directly out of searchResult window, you cannot guarantee that your sequence is running without any problems
Idea: Add a "checkup function" on the "reload" module in the stepSettings menu that all parameters are checked by name and value before any values will be overwritten. This checkup has to be done on each change of the called subsequence
