2 | |
2 | |
1 | |
1 | |
1 |
Hello
Execution of a single step is a process executing a lot of steps depending on looping and synchronization. Needing the option to call a PreExecuting and PostExecuting step before taking Looping, PreConditions and Synchronization options in consideration and after all other steps are executed. This is intended to custom step types for use with external customers.
Thanks Vagn
I'm declining this idea due to lack of community support.
