2 | |
2 | |
1 | |
1 | |
1 |
I would like a built-in tool in the Sequence Editor that would check my sequence file to verify that all expressions used in every step are valid and that all variables called exist. It would be nice to find errors during development/edit time rather than at run-time. I think this could significantly improve the usefulness of TestStand.
