2 | |
2 | |
1 | |
1 | |
1 |
Many times I need to run the MainSequence after a change somewhere in a subsequence. Because there is no shortcut key for that action (First go to the MainSequence then Execute->Run MainSequence) it is pretty time consuming. It would be nice to have that shortcut key in TestStand.
Best Regards,
Jick
