2 | |
2 | |
1 | |
1 | |
1 |
As we can read in this very good document, we can add information in header for UUT in Report.
It is mentionned that we can do that for StationInfo in the same way:
"The report below includes the custom data in the AdditionalData container. The process for adding custom Station data is similar, but uses the Parameters.ModelData.StationInfo property instead of Parameters.UUT."
In fact, it doesn't work in TestStand 2014 and later, certainly the same for 2013 because the default report plug-ins doesn't support it as you can see in the help of TestStand 2016.
Maybe NI can add it like it is done for UUT.AdditionalData. The goal is to avoid to put some Station Info in UUT result to show it easily in reports.
Best regards.
MaximeR
CLA - CTD
Maxime R.
CLA - Certified LabVIEW Architect / Architecte LabVIEW Certifié
CTA - Certified TestStand Architect / Architecte TestStand Certifié
