NI TestStand Idea Exchange
Scipio
TS Diff Tool to Properly Handle Homonym Sequences and For Loop Steps
Status: Completed
The sequence editor's (v4.1) diff tool doesn't properly step through the differences if it encounters a "For" loop step or a sequence call step that is a homonym of another sequence call step in the diff window. It basically gets in an infinite loop that can be exited by selecting the next step in the diff window.
Also, if a parameter is added to the parameter list of a sequence and is moved before other existing parameters, the tool doesn't identify the pre-existing steps as identical. It just markes them as deleted from the first sequence and added to the second sequence (therefore it prevents proper comparison).
2 Comments
dug9000
NI Employee (retired)
If you get a chance, please download an evaluation copy of TestStand 2010 and try out your use cases with the TestStand 2010 differ. There were major changes made to the differ in TestStand 2010. If you still see some of these issues please let us know.
WireWeaver
Status changed to: Completed
