LabVIEW executables update to the Windows settings when run. So, if the scrollbar size is increased (as is helpful with touch panels), the scrollbars adjust. However, TestStand called LabVIEW modules running under the Run-Time Engine do not update in size. This makes it hard to customize the value to the user's needs.
