NI TestStand Idea Exchange
BrianGShea@NGC
TestStand Deployment Utility Scripts
Status: New
When building any type of distribution it would be nice to have the following actions
1) Pre-Image Build Script -> Execute windows command or batch file
2) Post-Image Build -> Execute windows command or batch file
3) Post-Distribution Build -> Execute windows command or batch file
The purpose of the three entry points is to allow the user to preform actions of their choosing.
Action #1 is to be run just prior to Starting Analysis to allow the user to preform any automated actions prior to analyzing the build project.
Action #2 is to be run after the deployment image structure and all files are created on disk but before the distribution package is create. The purpose of this action is to allow the user to inject any files, update files, preform verification or hashing and so on. In my specific use case, I need to create a file that has relative paths and a hash value for each file being deployed. This process is automated but currently run manually prior to a package build.
Action #3 is to be run after the Distribution package is made. Automate any file steps such as uploading the file to a network location, or generating an automated email.
Each action should call the script with parameters such as path info, deployment name or provide a list of variables that users can choose to have added to the command line for each action.
If the action script or command returns a non-zero value the Build process should terminate.
Re-Posted from (https://forums.ni.com/t5/NI-TestStand/TestStand-Deployment-Utility-Scripts/td-p/4373139)
Brian G. Shea
Former Certified LabVIEW Architect
2 Comments
Elaine_R.
Active Participant
build script hooks would be great.
a full API for build (so I could make my own utility) would be even better 😅
I suspect they will tell us to switch to PackageManager, but there are so many things the TS build utility does right. it would be a shame to reinvent the wheel just to increase automation functionality
Parker123456789
I've recently switched to using the NI Package Builder. The TestStand Deployment Integration seems to work well enough, while giving an expanded list of capabilities already available in NI Package Builder.
I don't open NI Package Builder unless I really have to and just rely on a powershell build script. Script updates the build version, then builds it, then deploys the files to places..
version updating like so.. incase yall curious
# Update Pkg Version in .pbs
$myXML = New-Object System.Xml.XmlDocument
$myXML.PreserveWhitespace = $true
$myXML.Load($MyPkgBuilderSlnPath)
$dist = $myXML.Solution.Distributions.Distribution
$dist.Version = "$MyBuildVersion"
$dist.FileName = "$($dist.PackageName)_$($dist.Version)_$($dist.Architecture).nipkg"
$myXML.Save($MyPkgBuilderSlnPath)
Then calling it like so.. where I check the exit code to know if I should do post actions or not.
&$NiPkgBuilderExePath -o="$MyPkgBuilderSlnPath" -b=packages --verbose-off
$deployExitCode = $LastExitCode
I think my main reason for switching to Package Builder was really because I would get a consistently incorrect exit code from the normal TestStand Deployment tool
