-17325 wrong number of array indices
i have made a custom steptype with LV. The result data of this step is a byte array. I test this byte array with the multiplenumbertest function in the same step.
When i start the sequence for the first time the error (in the attachment) occured. The next times all is fine and no error appears. I have tried all possible settings at the bound tap (array).
greetings kschwede
Message Edited by Schwede on 04-08-2008 04:00 AM
Message 1 of 19
(5,432 Views)
hi,
what is the initial value of the data source string?
regards
ray farmer
Regards
Ray Farmer
Message 2 of 19
(5,422 Views)
hello,
where can i see it in TS?
schwede
Message 3 of 19
(5,422 Views)
you can see it in the Edit Limit dialog box.
regards
ray farmer
Regards
Ray Farmer
Message 4 of 19
(5,424 Views)
or you can view on the sequence view in the seqeditor when you open tree view.
right mouse click on the active sequence and then select open tree view.
regards
ray farmer
Regards
Ray Farmer
Message 5 of 19
(5,425 Views)
can you see the initial value?
schwede
Message 6 of 19
(5,422 Views)
Sorry here is the attachment.
Message 7 of 19
(5,422 Views)
Whats the initial size of Ansgangsdaten as you seem to be using Step.Ansgangsdaten[8] as the data source
regards
ray farmer
Regards
Ray Farmer
Message 8 of 19
(5,420 Views)
the size of the array is variable. For the initial size i have tried a lower and higer bound and initial as empty.
Message 9 of 19
(5,418 Views)
try setting the initial value to Step.Ansgangsdaten[0]
regards
Ray Farmer
Regards
Ray Farmer
Message 10 of 19
(5,413 Views)
