04-08-2008 03:56 AM - edited 04-08-2008 04:00 AM
I have tried all possible settings at the bound tap (array).Solved! Go to Solution.
04-08-2008 06:11 AM
hi,
what is the initial value of the data source string?
regards
ray farmer
04-08-2008 06:19 AM
hello,
where can i see it in TS?
schwede
04-08-2008 06:50 AM
you can see it in the Edit Limit dialog box.
regards
ray farmer
04-08-2008 06:54 AM
or you can view on the sequence view in the seqeditor when you open tree view.
right mouse click on the active sequence and then select open tree view.
regards
ray farmer
04-08-2008 07:20 AM
04-08-2008 07:21 AM
04-08-2008 08:02 AM
Whats the initial size of Ansgangsdaten as you seem to be using Step.Ansgangsdaten[8] as the data source
regards
ray farmer
04-08-2008 08:23 AM
the size of the array is variable. For the initial size i have tried a lower and higer bound and initial as empty.
04-08-2008 08:28 AM
