NI TestStand
-17500 System Our of Memory Exception
Hey colin.c,
The article mentioned above contains instructions that are specific for LabWindows™/CVI. In summary, it asks you to either upgrade to CVI 2012 SP1 or install a patched .reg file that updates a CVI Key.
Here are a few questions to better understand the issue on your end:
  1. When exactly do you get this error? Right after opening the OI or after a few test Runs? Do you see the memory usage increase over time or do you get a sudden peak of memory allocation and then the error?
  2. Do you also experience memory growth or even an OutOfMemory Exception when running from the Sequence Editor? if so, could you provide detail on the steps you take until you see the error?
  3. Have you done any customization to the default OI Executable?
Thanks in advance,
Felipe Flores
Technical Support Engineer
Message 11 of 15
(946 Views)
Thanks Feline, good to know and please see my answers below:
  1. Error only occurred after running the same sequence (with iteration) for 3+ consecutive days or more. The sequence continues to read data from EUT and writes into a CSV file. The memory usage of TestStand increases slowly over time, then error occurred when memory grow beyond 2+GB...
  2. It's for remote laptop to capture data from EUT, hence I've only ran this sequence on the TestStand Operator UI for consecutive days. The error messages normally occurred at steps "prompt message", "if", "end", "wait", and never at any of the .vi.
  3. No customization that I know of. Where (and how) can I check?
Side Note: I have previously disabled everything under "Result Processing" in case that was the contributor or memory growth, it has only delayed the error (i.e. allowed more iterations before out of memory).
That means something else is still taking up the memory over time. Is there any way to check (or breakdown further) to find out what exactly is taking up the memory during the iterations?
Message 12 of 15
(937 Views)
Thanks for the quick reply, colins.c.
Regarding answer #3, I'd expect to see customizations in the OI Source Code. If you are not aware of it, that's probably not the issue. Let's keep that part on hold for now.
So, TestStand divides results handling into 2 parts: results collection and results processing.
On the Results Processing part, I see that you are using on-the-fly reporting, which is a good practice for time extensive tests. Also, you noticed that removing the results processing part will delay the error. However, unchecking all result processing strategies only won't prevent TestStand to collect results.
To start checking the results collection process, could you please try the two strategies I highlight in the article Preventing Memory Issues with TestStand Report Generation?
Let me know how it goes.
Felipe Flores
Message 13 of 15
(926 Views)
I have same issue, could you tell me how to fix this issue?
Message 14 of 15
(798 Views)
The decision at the time was to work on higher priority issues first and put it aside. Unfortunately this was never revisited since then, thus couldn't help you mate..
Message 15 of 15
(762 Views)
