A Dot Net Error
Hello All,
I tried opening the fully featured user interface and got this error. I followed this link to register the dotNet Components manually http://digital.ni.com/public.nsf/allkb/D4177000FC64E620862577A700751B8C and I manually register the teapi.dll (also restarted the System), but nothing worked. Can anybody please help me to solve this issue.
AshwiN
(4,238 Views)
It seems that there is no .net Framework on your maschine.
you have to install it.
http://www.microsoft.com/downloads/en/details.aspx?FamilyID=0856eacb-4362-4b0d-8edd-aab15c5e04f5&dis...
Regards
juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(4,232 Views)
I checked twice, dotNet Framework 2.0 is present in my system, please tell me what could be other reasons for this error.
AshwiN
(4,229 Views)
That sounds bad, in this case i would re-install Teststand once again.
Hope this helps
Juergen
--Signature--
(4,219 Views)
Even after uinstalling the Teststang it is giving this error. I hope particular dot Net component is not working. After clicking 'continue' to the error dialog it takes me to the Sequence Editor of the Fully Featured OI (Ctl+Shift+Alt+Insert) , but the Insertion palette is missing. Some time it is throwing the "Microsoft Visual C++ Runtime library" error also. Any option ????
AshwiN
(4,207 Views)
Accepted by Ashwin_S
I am sorry i have no other idea.
but just one other question. TestStand Editor is running well on this maschine ?
Maybe the "blue ones" have some hints for  you.
Regards
Juergen
--Signature--
(4,202 Views)
Hello dodek,
It's hard to beleive that the Templates.ini is the culprit, I jus deleted it and the Error is gone. I hope the file is corrupted, after observing the sequence Editor only I can understand this. Very thanks for your support dodek
AshwiN
(4,200 Views)
