01-10-2012 04:33 AM
I need to add this subproperties ( Logging.StepResult.TS.SequenceCall) but i can't. really i don't know What's this variable TS.SequenceCall because it does not appear in the list.
I use TestStand 2.0 version. You can see in the picture the list displayed.
01-10-2012 09:25 AM
You shouldn't have to add anything like that manually. TS.SequenceCall is just the properties that are part of the result for a sequence call step.
Hope this helps,
-Doug
