NI TestStand
How to disable report-tab after testrun
i am using TestStand 4.2.1.
After each testrun there is a new tab created with a report and the test-results. The same report is also created as report-file on harddisk.
Question is: How can i disable the new tab? So that after the test is finished it displays again the testsequence-tab?
Currently i always have to close the report-tab to see the sequence again.
Thanks for help
(2,967 Views)
It looks like the only option would be to skip the Read Entire Report step in your process model.
Ctrl-D is a handy shortcut to close it quickly after execution.  It closes all finished executions.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(2,963 Views)
