NI TestStand
AND expression in an IF condition
Hi guys,
How to use an AND expression in an IF condition?
I tried "foo1 != true AND foo2 != true" or "foo1 != true & foo2 != true". But this gives an expression error.
(3,041 Views)
You need to use && (similar to C/C++)
You would use AND if you what to AND two value together.
Check out the TestStand Help for more information.
Regards
Ray Farmer
(3,036 Views)
TestStand also has parameterized version of the AND and OR operations - AllOf() and AnyOf(), respectively.
(3,021 Views)
