NI TestStand
APIs for Station Globals
Could someone please point me to the TS APIs to Create/Set/Get/Delete Station Global variables?
Sriharsha
(3,761 Views)
All the methods are using the PropertyObject class.
Getting Values - GetValNumeric, GetValString, GetValBoolean, etc...
Setting Values - SetValNumeric, SetValString, SetValBoolean
Creating Variables - Same as above, but use the InsertIfMissing flag (0x1) for the options parameter).
Deleting Variables - DeleteSubProperty
Hope this helps!
Allen P.
NI
(3,757 Views)
Allen,
I tried the following code, but it does not seem to work:
            PropertyObjectFile sgFile = m_TSEngine.GlobalsFile;
            sgFile.AsPropertyObject().SetValBoolean("Temp", PropertyOptions.PropOption_InsertIfMissing, true);
            sgFile.SaveFileIfModified(false);
            m_TSEngine.CommitGlobalsToDisk(false);
After I run the code can I do not see the Variable Temp created under StationGlobals. Please let me know what is wrong.
Sriharsha
(3,755 Views)
Engine.GlobalsFile is a PropertyObjectFile, not a PropertyObject.
Use Engine.Globals instead.
(3,752 Views)
Howdy Sriharsha,
Attached is an zip fle with an example sequence that uses two activeX calls to insert a Station Global variable.
Hope this helps!
Best Regards,
Jonathan N.
(3,736 Views)
