NI TestStand
Do you know what means the error -17502
Message 1 of 8
(5,402 Views)
I looked up the code in the error codes section of the TestStand online help. The code is: "Error OS Exception".
This means that TestStand caught an access violation or other unexpected non-TestStand exception.  Ways this can happen include calling a code module that generates an access violation or calling a code module with an argument list that does not match the actual parameter list.
Message 2 of 8
(5,393 Views)
But How can I take off this failure becasue I can not open the sequence editor (TestStand)???
Message 3 of 8
(5,389 Views)
Hi Victor,
What is the version of teststand you're using? How did you first encounter this error? I am trying to replicating this error on my side and would like to know when does this error occur?
Sometimes it is a possiblity that one of your registry keys located at HKEY_CURRENT_USER»SOFTWARE»NATIONAL INSTRUMENTS »TESTSTAND might have been corrupted. So deleting this folder should help getting rid of the error.
But since this is an issue, could you post your exported registry keys, so that we can investigate a little further into the issue. To export the registry key entry, right click on TestStand at ( HKEY_CURRENT_USER»SOFTWARE»NATIONAL INSTRUMENTS »TESTSTAND) and select export. Please attach this file here so that we could further take a look at it.
I hope to hear back from you soon.
SijinK
National Instruments.
Message Edited by Support on 07-08-2005 11:47 AM
Message 4 of 8
(5,376 Views)
This failure Happened again, I did what you suggested last time and is working, but I need to investigate why sometimes this failure appears. Thanks!!!
Message 5 of 8
(5,234 Views)
This error just occurred on a system I have running TestStand v1.0 with NT
Could you post the actual steps you took to resolve?
Message 6 of 8
(4,937 Views)
I did what SijinK suggested me, I just ereased the folder and then TestStand worked fine, try this option ...Hope it can help you....
Message 7 of 8
(4,926 Views)
Deleting that folder indeed took care of it - just wanted to coonfirm that was all that was needed.
Message 8 of 8
(4,902 Views)
