NI TestStand
ATDF, STDF reports ?
I was wondering if someone exports the report generated from Teststand, in STDF (Standard Test Data Format) or ATDF(Ascii ....). Can you tell me how did you make it ?
(5,177 Views)
I did a Google search for ATDF and STDF without much luck. Where can I find documentation on these formats? It would be nice to have a standard format for exchanging calibration data between calibration labs and equipment users for traceability. I was thinking of an XML solution, but if there is already a standard, that would be great.
(5,175 Views)
Found this, but would like to know if anybody has gone through this.
(5,085 Views)
This the stdf spec document. You may want to try out some stdf analysis software. I would recommed you SEDana from Salland Engineering.
Joseph Chang
(4,559 Views)
