03-18-2008 05:28 AM
03-27-2008 06:46 AM
04-14-2008 04:47 PM
Hi Cardinal1664,
I just wanted to follow up with you and see if you've gotten your system working the way you want it to and the sequence files load the vi's from the right directories.
Also, I wanted to point out that the first item in the search directories is usually the directory of the current sequence file.
What this means is that if all modules/subsequences are located in a path are relative to the path of the sequence file, and you use relative paths, it should work.
04-15-2008 01:52 AM
