NI TestStand
ATML Toolkit Compatibility
I am using TestStand 4.2 (I cannot upgrade for business and contractual reasons). I also need ATML Toolkit, and am trying to evaluate if ATML Toolkit 2013 is compatible with TestStand 4.2.
I can see from "TestStand ATML Toolkit 2013 Help" that "The ATML TD translator uses the translator framework included in TestStand 4.0 or later to translate a TD file into a TestStand sequence file"
Could you please confirm that TestStand 4.2 is indeed compatible with ATML Toolkit 2013, before I commit to a license.
(1,204 Views)
HI,
ATML Toolkit 2012 was the last version that supported TS 4.2. Can you please discuss with your sales person what is the best way to obtain a license for ATML Toolkit 2012.
Anand Jain
NI
(1,165 Views)
Thanks Anand Jain, I will put in a request with my local distributer
(1,154 Views)
