NI TestStand
Unique ID for each Test Execution from TestUUT level
I'm looking for unique ID for each time when TestUUT is executed.
I could find ID for
  • each test sockets using RunState.TestSocket.MyIndex,
  • each UUT uses its own serial number as ID,
  • each Step Unique ID
But I'm looking for still top-level ID, i.e., ID of each run/execution of the sequence.  Is there any such?
Ajay.
Ajay MV
Message 1 of 8
(2,623 Views)
How about Execution.Id or Thread.Id?
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
Message 2 of 8
(2,608 Views)
I used RunState.Execution.UniqueID and it always gives the same ID how many ever times I run the sequence again.  It changes only after I restart the Teststand.
I believe thread ID would also be less helpful, I expect there could be numerous threads that could invoke under a single run.  I will give it a try, do you know where I can find it?  Is it in RunState.xxx.xxx like?
Ajay MV
Message 3 of 8
(2,603 Views)
You can get it in many ways. See diagram: https://zone.ni.com/reference/en-XX/help/370052AA-01/tsapiref/infotopics/teststand_api/
But normally you will get it from Execution (here you also have many options): https://zone.ni.com/reference/en-XX/help/370052AA-01/tsapiref/reftopics/execution/
Michał Bieńkowski
CLA, CTA, CPI
Message 4 of 8
(2,594 Views)
I think you meant Execution.Id. Yes, this behavior is expected. But if you want some different ID each time you start execution, combine Execution.SecondsAtStart with Execution.Id: Str(RunState.Execution.Id) + Str(RunState.Execution.SecondsAtStart*10000000)
Michał Bieńkowski
CLA, CTA, CPI
Message 5 of 8
(2,592 Views)
@bienieck Thanks for feedback Both Execution.Id and SecondsAtStart are not unique between the test sockets as in the screenshots below.   I'm looking for an ID which never changes between test sockets but is unique for each TestUUTs entry point execution.
Ajay MV
Message 6 of 8
(2,582 Views)
Can't you use socket execution id? It should be unique. Combine it with timestamp and it's done.
Michał Bieńkowski
CLA, CTA, CPI
Message 7 of 8
(2,578 Views)
Or maybe generate GUID using .NET when new socket execution starts and save it as execution runtime variable.
https://docs.microsoft.com/pl-pl/dotnet/api/system.guid.newguid
Michał Bieńkowski
CLA, CTA, CPI
Message 8 of 8
(2,575 Views)
