Abort Command
This should be fairly straight forward, but I have some VIs in my test sequence that come up as dialogs/pop-ups. The user can close these dialogs, but I want the test sequence to abort if the user does this.  I have panel close setup as an event in the sequence that return a boolean value as TRUE.  I want this trigger a manual abort in the test sequence, prefearable as a Post-Expression.
(4,917 Views)
You can use the Abort() Method to abort the execution, by inserting into the Post-Expression like this:
Step.Result.PassFail == False ? {RunState.Execution.Abort()} : {}
(You can change the "Step.Result.PassFail == False" for a boolean check on your returned value, if you so wish)
Charlie Rodway | Principal Software Engineer | Certified TestStand Architect (CTA)
Computer Controlled Solutions Ltd | NI Silver Alliance Partner | GDevCon#1 Sponsor
(4,906 Views)
I recommend using Terminate instead of Abort.  Abort will kill everything and immediately exit, including the Process Model.  Terminate will run your cleanup routine.
My 2 cents,
jigg
CTA, CLA
testeract.com
(4,902 Views)
Accepted by SHentchel
I agree with Jigg,  I'd prefer Terminate as it works through the cleanups turning everything off nicely.
You can find a summary here: Terminating and Aborting Executions
If you still want to terminate via your Step Post-Expression, you could use:
Step.Result.PassFail == False ? {RunState.Execution.Terminate()} : {}
I hope this helps,
(4,892 Views)
I used:
 did exactly what we needed. Thank you for you both for your help.
(4,880 Views)
Spoiler
No problem - glad I could help!
(4,865 Views)
A little more information if you end up needing it later down the road.
You will likely need to do a RunState.Exection.InInteractiveMode? and then call Runstate.Execution.TerminateInteractiveExection or RunState.Execution.Terminate
If your users never do interactive executions, then you can ignore this.
(4,679 Views)
