NI TestStand
Abort unloads all modules
I have a working TestStand project in TS2014, now I installed TS2021 and try to run the old sequences. Executing sequences is not a problem, but I discovered something strange between the two TS versions.
Aborting an execution in TS2021 unloads all modules, which makes it complicated to debug my sequences. Is it a normal behaviour? TS20214 doesn't unload them, each asynchronously launched code are continue running.
Is there a special setting for TS2021 to solve it? I searched about it on the internet, nothing found 😞
I use TestStand 2021 32-bit, Version 21.0.0.49156
Message 1 of 1
(949 Views)
