NI TestStand
Teststand termination
I have used preUUT window in teststand with some conditions. If the condition was true I want to terminate the whole sequence and run postuut. Now i have used terminate all function to terminate application on preUUT sequence but it won't terminate .
Anyone give me some suggestion to terminate sequence properly while the preUUT condition fails.
(1,073 Views)
Please look at your PreUUT sequence.  You will find that it has a boolean, Parameters.ContinueTesting.  Use an expression step to set Parameters.ContinueTesting.  Example:  Parameters.ContinueTesting = !condition.  If condition is true then Parameters.ContinueTesting will be false. The process model reads this and will stop the test.
(1,026 Views)
