NI TestStand
Step parameters do not match sequence parameters
I struggle with a big problem....
I use a step to parameterize the next step depending on the used TestObject. This parameterization step has sometimes changes (e.g. new parameters)
Then in many, many steps I have the problem that step parameters do not match sequence parameters.
When I klick the red Icon I get many lines with "The expression cannot be empty" that lead to errors. To resolve this I have to set every value to default bay hand. This are thousands of klicks.
So my question is: is it possible to avoid this? Is ist possible to set all new values to default-values by default when reloading the sequence prototype?
Does ist make a difference when not using this check mark?
I would be very pleased if someone could help me!!
Message 1 of 1
(1,049 Views)
