NI TestStand
Access Locals.x from offline processing
Hi Forum
I am trying to add some Locals to my report database. For this I set the flag "Include in Report" 0x2000 for these variables. However when I try to access them from the offline processing I get the error "Unknown variable or property".
How do I access locals saved for the report from offline processing?
Raphael
PS: I followed the instructions from the second Note here: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019QDNSA2&l=de-CH
Before I tried adding it as properties with the instructions from here without success, there was a runtime error creating the variables: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019QDNSA2&l=de-CH
(1,654 Views)
Hello Raphael,
What do you mean by saying "I try to access them from the offline processing"?
Do you get same error if you try to do same on simple project?
__________________________________________
The best way to thank, is to give KUDOS
(1,596 Views)
Hi VaKi
in a simple project I can access the variables, but not after I load it into the offline processin..
(1,571 Views)
Do you use TestStand Offline Results Processing Utility?
(1,407 Views)
