NI TestStand
Access SequenceFileGlobals of my sequence file in the Process Model
How can I access the SequenceFileGlobals of my sequence file in the  Process Model
and I am using the active x function: Execution.GetFileGlobals(RunState.ProcessModelClient).
But the parameter RunState.ProcessModelClient is not available in my process model
can anybody help me?
Thank You
regards
Samuel
Message 1 of 8
(3,943 Views)
You will need to look at RunState.ProcessModelClient.FileGlobalDefaults.
Regards
Ray Farmer
Regards
Ray Farmer
Message 2 of 8
(3,941 Views)
Ray,
I want to save my reports in different folders dependend on the path which a Sequencefileglobals of my sequence file contains.
I thought that wenn I have access on the sequencfileglobals in the process modell., I can set Parameters.ReportOptions.Directory with the path which the SequenceFileGlobals from my sequence file contains
is that a good idea or is a other method better?
regards samuel
Message 3 of 8
(3,937 Views)
Hi Samuel,
Rather than doing this in the processmodel, why not have a Callback sequence ReportOptions as part of your sequence file. You can then set the Parameters.ReportOptions.Directory from the value held in your SequenceFile Globals within the ReportOptions.
You dont have to modify your process model this way.
Regards
Ray Farmer
Regards
Ray Farmer
Message 4 of 8
(3,936 Views)
Ray,
Do you have an example for this?
thank you
samuel
Message 5 of 8
(3,933 Views)
There is an example at the following link which I used the ReportOptions in the SequenceFile, in this case I set up the xml format and I obtain the values from Locals, but it could have been from the FileGlobals.
http://forums.ni.com/ni/board/message?board.id=330&message.id=11031
Regards
Ray Farmer
Regards
Ray Farmer
Message 6 of 8
(3,929 Views)
Ray,
as I can see, the ReportOptions sequence call  where you set the path is executed before the PreUUT. In my application, I will get the path in the PreUUT. So it is not possible to do this.
can I set the ReportOptions later?
regards samuel
Message 7 of 8
(3,927 Views)
Samuel,
I see no obvious reason why not, You would have to move the step that calls the ReportOptions sequenceCall in your process model entry point sequences.
Seeing as you are having to change the process model, you might as well go back to your original idea.
Regards
Ray Farmer
Regards
Ray Farmer
Message 8 of 8
(3,924 Views)
