NI TestStand
Why a value of Sequence File Global didn't change ?
I change the Sequence File Global into ModelOptions subsequence, but after that in MainSequence I see that the value isn't changed. Why do I have the problem?
(3,554 Views)
Have you set the Sequence File Globals to "All Executions Share the Same File Globals" in the SequenceFile Properties?
Regards
Ray Farmer
Regards
Ray Farmer
(3,552 Views)
No, it was "separate...." 🙂 I didn't know, thank you!!!
(3,550 Views)
But it didn't help :-(.
I set to "Share...", I have the same problem. Why?
(3,548 Views)
Sorry, it works.
Thank you !
(3,547 Views)
Thats okSmiley Happy
Regards
Ray Farmer
Regards
Ray Farmer
(3,543 Views)
