Access to locals in the sequence
Accepted by topic author john7
Hi John
Use the following Methods
SequenceFile.GetSequence ( index) to return a reference to the Sequence
or use
SequenceFile.GetSequenceByName ( sequenceNameParam) or by a name
ie
SequenceFile.GetSequenceByName ( "MainSequence")
then once you have your Sequence reference then you can get a PropertyObject reference to Locals.
 Sequence.Locals as a PropertyObject
eg
 Sequence seq = seq_file.GetSequence ( index = 0) (usually for the MainSequence)
but better to use
 Sequence seq = GetSequenceByName ( "MainSequence")
then to get you value from your local
 PropertyObject str = seq.Locals.GetValString("strTextBox", 0);
Because you have a reference to Locals for the required sequence you dont use "Locals" in the Lookup String.
You only need the full Lookup string if you have the Sequence Context.
Hope this helps
Regards
Ray Farmer
Message 11 of 14
(1,184 Views)
Thanks a lot! It works!
Message 12 of 14
(1,181 Views)
One more thing. When  i change local variable i see the change in the code but sequence stays unchanged.
Engine my_egine = axApplicationMgr.GetEngine();
SequenceFile seq_file = my_egine.GetSequenceFileEx(seq_file_path, TypeConflictHandlerTypes.ConflictHandler_UseGlobalType);
Sequence seq = seq_file.GetSequenceByName("MainSequence");
seq.Locals.SetValString("strTextBox", 0, "my new string");
string str = seq.Locals.GetValString("strTextBox", 0);
MessageBox.Show(str);
I see "my new string" in message box but in the sequense the text is "Hello World".
Message 13 of 14
(1,179 Views)
Hi John,
Answered here
Regards
Ray Farmer
Message 14 of 14
(1,154 Views)
