NI TestStand
Action engine synchronization in testsand UI
Message 1 of 10
(5,942 Views)
please Ignore the first  message
Message 2 of 10
(5,941 Views)
Message 3 of 10
(5,940 Views)
ui-messages r lost in comm.
Message 4 of 10
(5,938 Views)
sorry for the fuss but  I was not able to   write to the  board  (some bug with the HTML editor maybe - gave me correction suggestions everytime bfore posting)
Message 5 of 10
(5,877 Views)
I  am using these Action Engine  &  the  functioning is   sporadic.
they are able to deliver the UI messages sometimes &  sometimes not.
Message 6 of 10
(5,876 Views)
Hi aparab,
thanks for posting here.
Could cou please provide more detailed information to your question?
- Which Teststand Version are you using.
- What are you generally trying to do.
- In which situation does the problem occur?
Please also provide some demo-code narrowed down to the problematic part to let us reproduce the behaviour.
Peter
Message 7 of 10
(5,875 Views)
I think you are not using the Action Engine correctly see: http://www.pearl.fr/peripheriques/gadgets-usb/fusil-usb-avec-lunette-de-visee-par-webcam_PX1420.html
You don't have an enum (type of action), so I guess you are not using the un-initialized shift register correctly.
PS: why would you write in the action engine the same data every 2ms anyway?
Rodéric L
Certified LabVIEW Architect
Message 8 of 10
(5,867 Views)
thanks guys for the response
hi Roderic its agood pt abrt the shift register
Abt the  while loop timing  , still in design  no particular reason.
Hi Peter,
The action engi ne that I am using to  get UI Messages from testsand   works intermittently i.e.  (luck by chance)
sometiimes I am able  to get some UI Mges & sometimes other.
why this could be happening ->not able to conclude conclusively ->  but may be write & read are nt synchronized
i use teststand 2012 sp1 & labview 2012 sp1
i will try to provde a sample code
Message 9 of 10
(5,846 Views)
You only need to write the cluster of references once in your action engine. Then all you have to do is read it. So you have to make two "actions" (cases) write and read (use an enum) and store the date in a shift register.
Rodéric L
Message 10 of 10
(5,838 Views)
