NI TestStand
ActiveX Automation server error on deployed TestStand
I'm trying to deploy TestSTand 2.0 + LabVIEW 6.1 on a PC under Win-2K.
I created and deployed TS Engine and Operator Interface for LV.
I try to deploy the "Auto.seq" test from the TS exemples.
Of course, it works on my Development system.
On the deployed system, I got an error : -18351; An error occurred reading an ActiveX Automation server type library.
Step 'Read Database Option - Construct' of sequence 'Get Database Options' in 'SequentialModel.seq'
Step 'Read Database Option - Read Options' of sequence 'Get Database Options' in 'SequentialModel.seq'
After having ignored those 2 errors, the tests goes on normally and the report looks fine.
I also get this error opening the database configuration:
Step 'Read Database Option - Construct' of sequence 'Edit Database Options' in 'Database.seq'
From answers already given for similar subjects, I've checked that TsDBOptions.dll is present and registered (done regsvr32...) on the PC.
Can someone help ?
Note: upgrading to more recent TS + LV versions is not a solution!
Message 1 of 1
(3,265 Views)
