NI TestStand
Labview hangs
Labview hangs when I run the attached vi second time. The attached vi work perfectly first time. when run second time labview hangs up. I need to stop labview from the task manager. Else after every run i need to exit labview and start the vi again.
Is there any problem in the way I handle the references?
Regards
Gopal
(3,472 Views)
Hi
Sorry I failed to attached the vi in the earlier posting.
Regards
Gopal
(3,474 Views)
Hi Gopal,
Unless you need to use ApplicationManager for some other reason, just use Engine. Also, you need to call release sequence file and it doesn't look like you need to save the sequence file. I have modified and attached the code with these changes for your convenience.
(3,446 Views)
