ActiveX Object Reference
Hello.
I am trying to control Vector CANalyzer using a TestStand ActiveX step as shown below. What am I supposed to put in Object Reference?
Thank you.
(1,161 Views)
What does the Vector API description say?
(1,135 Views)
You either put there object reference variable with the measurement object (I guessed you need measurement object because you have selected it in the class field) or you need to use the "create object" checkbox on the right.
BTW You can always click on the empty field and press F1 to check the help file.
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
(1,036 Views)
