04-03-2025 01:46 PM
Hello.
I am trying to control Vector CANalyzer using a TestStand ActiveX step as shown below. What am I supposed to put in Object Reference?
Thank you.
04-04-2025 01:56 AM
What does the Vector API description say?
05-14-2025 04:17 PM - edited 05-14-2025 04:19 PM
You either put there object reference variable with the measurement object (I guessed you need measurement object because you have selected it in the class field) or you need to use the "create object" checkbox on the right.
BTW You can always click on the empty field and press F1 to check the help file.
