NI TestStand
Add Data stored in locals to report with offline results processing
Hi Raphael,
If understand well what you are trying to do is that you write into the offline files to perform the synchronisation in the DB when this one is available.
To me, this should happen in the test socket execution. So the Run.Root.Locals should work (so without doubling the Root).
However, I wonder if you set this process to be done in parallel with your execution. If so this might be the source of the problem.
Can you check in Configure -> Result Processing if your offline result processor is set to be done in parallel ?
If so, try setting it to be executed at the end of each socket execution.
CLA, CTA, LV Champion
View Cyril Gambini's profile on LinkedIn
This post is made under CC BY 4.0 DEED licensing
Message 11 of 20
(2,674 Views)
Hi CyGa
offline processing is run only between 2-3 in the morning when there are no tests active. It is guaranteed to not run during the test.
The setup in teststand:
Thanks for the input,
Raphael
Message 12 of 20
(2,669 Views)
The synchonisation tool runs at night. But the files are created each time you run a test socket.
Can you activate the 'Show more options' check box and send me a screen copy ?
When activated you should be able to set if that processor runs in parallel or not.
Message 13 of 20
(2,667 Views)
Hi CyGa
this one?
Thanks, Raphael
Message 14 of 20
(2,663 Views)
Yes this one.
Set it to No, and re-test.
Message 15 of 20
(2,660 Views)
Thanks, I set it to no and started the test, it will take until tomorrow to have the results. I will report results here
Message 16 of 20
(2,663 Views)
Hi CyGa
Unfortunately this didn't make the data appear neither in Parameters.UUT.AdditionalData.xy, Logging.UUT.AdditionalData.xy, Runstate.Root.Locals.xy and also not Runstate.Root.Root.Locals.xy.
Is there a browser for those files that teststand writes for the offline processing?
Message 17 of 20
(2,647 Views)
Hi Raphael,
I'm not aware of such browser.
This doesn't mean it doesn't exist though.
I'm not sure to understand really what's happening here, and I'm not sure I fully understand your use case.
To me the offline file should be populated with all necessary values and their origin at the test time.
Then the synchronisation tool, when processing the files, should only read them and push the data back to the linked DB.
I don't understand why the tool is complaining about a missing variable : of course this variable is not availabe at processing time in TestStand. But it should be available within the offline file !
I'm afraid I can't help much... You should maybe contact NI's support !
Message 18 of 20
(2,640 Views)
Hi CyGa
I have scheduled a call with NI for tomorrow since I am working on this with support for a while. In the meantime I found yet another solution:
https://forums.ni.com/t5/NI-TestStand/Log-Additional-Result-to-Specific-Column-in-Database/td-p/3615...
I am testing this at this moment and will update this thread with the status.
Thanks!
Message 19 of 20
(2,635 Views)
Accepted by raphael.wittwer
Hello Forum
it works!!
The missing piece of the puzzle was that the contents of RunState.Root.Locals.UUT.AdditionalData is moved to Logging.UUT.AdditionalData.
The data is written in a Statement in the main Sequence: RunState.Root.Locals.UUT.AdditionalData.SetValNumber("CMUVoltageDelta",1,Locals.CMUVoltageDelta)
And read in Offline Processing:
Logging.UUT.AdditionalData.CMUVoltageDelta
Thanks for all the help!
Raphael
Message 20 of 20
(2,591 Views)
