NI TestStand
Add user to User group in Users.ini file using C#
Using a C# application, we are trying to add/delete a user from TestStand Users.ini file.
The CreateDeleteUsers.seq file in the TestStand  samples is being used as reference.
We have observed that we are able to add the user to the user file list using
engine.UsersFile.UserList.SetPropertyObjectByOffset(0, 0X1, newUser.AsPropertyObject());
However, when we try to add the user to the user group, the sample in  CreateDeleteUsers.seq file says
RunState.Engine.GetUserGroup(Locals.GroupName).Members.SetPropertyObjectByOffset(0, 0x1, Locals.User.AsUser.LoginName)
If we try to replicate this in C#, the API looks for the final parameter (which is LoginName in the CreateDeleteUsers.seq file) as a property object
engine.GetUserGroup(this.GroupName).Members.SetPropertyObjectByOffset(0, 0X1, newUser.AsPropertyObject());
This causes an object reference exception when we run the application.
Please advise on the proper procedure to follow.
(3,519 Views)
Accepted by Arun Padmanabhan
Arun -
The members property is an array of string, so the 3rd parameter to SetPropertyObjectByOffset requires a string property object, ie. the user name, and not the user object. Passing the user object will error with "-17308; Specified value does not have the expected type.". The example should really be using SetValStringByOffset to be more clear so that you specify only the actual string user name.
Message Edited by Scott Richardson on 11-17-2008 10:44 AM
Scott Richardson
https://testeract.com
(3,511 Views)
