Allof, Anyoff used on Arrayand other Array Mathmatics
Pretty sure this should be set up as an improvement but as far as I could tell you cannot Allof or Anyof a Boolean array. Its kind of a pain to type out locals.array[0],locals.array[1],...etc for say 50 variables. any thoughts on this or suggestions on going about it a different way?
(4,473 Views)
is this the one you are talking about?
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(4,428 Views)
Accepted by brett.fowler.L3
Hi Brett,
Yes - it would be great to drop an array into these two functions rather than call out each element but unfortunately that's how they work Smiley Indifferent
However, you can use the Contains() function to achieve the desired effect:
Locals.Any = Contains(Locals.Array, True) //Sets Any to True if any of the elements in Array are True
Locals.All = Not(Contains(Locals.Array, False)) //Sets All to True if all of the elements in Array are True
I hope this helps,
Charlie Rodway | Principal Software Engineer | Certified TestStand Architect (CTA)
Computer Controlled Solutions Ltd | NI Silver Alliance Partner | GDevCon#1 Sponsor
(4,423 Views)
yup!
(4,412 Views)
Contains sounds good ill give it a try but it sounds like it will work for what im attempting to accomplish. Thanks!
(4,410 Views)
No problem, glad I could help!
(4,406 Views)
