NI TestStand
Always Show Type Conflict in File Dialog
here is a very strange questions, in the teststand(2014) main.seq had about 7 step in MainSequence,all is call sub seq file  like New Bitmap Image (3).bmp
now when i double chick one of the steps to open sub seq ,the Dialog Type Conflict in File is show
but the type is the same , also the  summary of differences is null.
if i chick OK ,sub seq file can be open, and i do save it .
but when i close the sub seq file and try to double chick the step open again,
the same Dialog Type Conflict in File show again.
i try a lot of ways but can't fix it.
this is too strange, I even can't find the same questions in web, does someone can help?
thanks!
(3,664 Views)
Can you send the rest of the text from the scroll window in that dialog box?  It will help know which file to look in and which datatype to look at.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,601 Views)
Accepted by yystars20
Thanks for reply.
This problem had identified the cause,is because the commend of the type had some strange characters
Type Conflict in File Dialog :
This problem will even lead to can't copy this MM_PCBA_Block  type(or variable)  to an new empty sequences file.
Error message is:
(3,547 Views)
If you delete those strange characters do the errors go away?
jigg
CTA, CLA
testeract.com
(3,544 Views)
