Application Domains
Does NI TestStand still limit .NET implementations and code modules to existing within a single application domain?
(139 Views)
Newer versions of TestStand supports .NET 8. So now, instead of AppDomain, it is AssemblyLoadContext (ALC). By default, TestStand uses one ALC for all .NET code module execution and a separate ALC for edit time scenarios like module intellisense.
In next version of TestStand, we plan to have an opt-in feature where a step type can specify that all .NET modules related to that step type (code module, substeps, step settings pane) will be executed in a different ALC. We also intend to have the opt-in feature where a group of step types can specify that they want to use the same ALC.
(120 Views)
