NI TestStand
Application Manager... but within Sequence Editor
I have incorporated UserMessage calls into my built GUI app.
However, I when coding and running from SeqEditor, I want to open a window that receives and shows all the messages.
How can I obtain the Application Manager in order to register the event callback?
(2,027 Views)
OK, I thought I figured it out but I didn't.
What is handling UserMessages when running inside the Sequence Editor?  How can I register for those messages?
(2,025 Views)
FWIW, from when I worked with TestStand years ago I vaguely remember a customer implementing a panel where they used a code module in some callback like Login and it would display a dialog and register a UserMessages callback and the messages would appear in the floating panel. Then they would shutdown the panel in reverse, like a Logout callback. The key was that the panel implementation could not rely on an execution continuing to run in the background. I do not remember what language they were using though.
Scott Richardson
https://testeract.com
(2,002 Views)
Accepted by Jed_Davidow
I get some code module running in parallel of a sequence (code module call from a sequence in a NewThread for instance), reacting to UIMessages.
I used the following kind of code:
The trick is the constant for the Variant To Data VI. Then, you can register a callback on the App Manager reference.
Hope this helps,
(1,999 Views)
