I dont know if you are using custom step types for this project.
But as a future reference. It would be easier to make an update to your step by modifying the step types and then allowing the sequencefile to pull in the step type when it is loaded.
The only point you will need to keep in mind is :-
The code module can not be placed in the Specify Module. You will have to use a Post Step.
The reason is that if the code module is placed in the Specify Module location, then when your custom step is used in the sequence and you want to modify it by modify the Step Type. When make every instance of the step type take on the changes, then every preporty except the code module will be changed. Hope this make sense.
Regards
Ray Farmer
Regards
Ray Farmer
