NI TestStand
user manager in operator interface
How can I add/edit list of users in TestStand Operator Interface?
(3,353 Views)
Hi hss,
In your teststand examples is a useful example called CreateDeleteUsers.seq
It demonstration creating and deleting of user by running a sequence and using the TS API calls.
To simply add the capababilty you require to your OI, all you need to do is add it to the tools menu.
See attached bmp showing CreateDeleteUsers.seq linked in the Tools Menu. Also note that its only available in the Operate Interface.
Beware, this example is only a demonstration and requires additional error checking such as checking for duplicate entries.
Hope this help
Ray Farmer
Regards
Ray Farmer
(3,352 Views)
Hello hss,
In addition to Ray's suggestion, you could look at the Knowledge Base article Why is the User Manager Not Built into the Shipping TestStand Operator Interfaces? which will show you how to add the User Manager as an entry in your Operator Interface's Tools menu.
David Mc.
NI Applications Engineer
(3,352 Views)
