NI TestStand
Are there other Stylesheets for XML-Reports?
Are there any other XML-Stylesheets aside from the 3 (expand, horizontal, report) in TerstStand?
Another question:
If I create new Steps in TestStand, normaly all the steps appears in the report, except if i edge off the hook in the Run options. Is there a possibility to say, all new Steps are not show in the report and i mark this one which i will see in the report.
Kind regards
Bastian
(3,376 Views)
Hi Bastian
I found this forums message
http://forums.ni.com/ni/board/message?board.id=330&message.id=2860&requireLogin=Fals
hope this helps
regards
Manuel
(3,361 Views)
Just an update: In addition to the built in Style Sheets, you could modify the existing Style Sheets to display the information as you choose.
TestStand 4.2 features improved XML Style Sheets that are restructured to reduce the time required to generate HTML output from XML report files and to simplify the task of modifying style sheets so that you can change the appearance and content of XML reports.
For more information about customizing TestStand XML report style sheets and using the included XML schemas, refer to:
NI TestStand Help: XML Report Style Sheets
Jervin Justin
NI TestStand Product Manager
(2,999 Views)
