NI TestStand
Array operations in TestStnand
I have a statement step in my sequence where I try and calculate the difference between two variables. The variables are defined as arrays (1 diminsion) with 8 elements. My expression looks like: Locals.z = Locals.x - Locals.y. I have checked to see that the x and y arrays are populated with data when I execute by using the watch expression pane, but I get the following error at my statement step and the z array never gets filled.
Details: The post-expression for the step 'Loop Delta' could not be evaluated.
Expected Number, found Array of Numbers.
Error Code: -17308; Specified value does not have the expected type.
Does anyone know what I am doing wrong?
(3,952 Views)
The "-" operator only applies to numeric values, not arrays.
You can loop and calculate the result for each index.
Init Expression: RunState.LoopIndex = 0
Increment Expr: RunState.LoopIndex += 1
Loop While Expr: RunState.LoopIndex < 8
Step Expression: Locals.z[RunState.LoopIndex] = Locals.x[RunState.LoopIndex] - Locals.y[RunState.LoopIndex]
This approach is fine for simple operations on relatively small arrays, but for large arrays or more complex operations, place this functionality in a language module (C, LabVIEW, etc.) that is better suited for performing mathematical operations.
(3,951 Views)
Hello there,
Can anyone improve on this scripting?
Seems like an array compare function would be most useful as a standard scripting function. I'm trying to simply compare to two strings (imported as U8's for Unicode and NULL '\0' reasons)
-Chroma
(3,736 Views)
