NI TestStand
Why is my string return (from a c# dll) is limited to 256 characters in TestStand
I build a .NET object in c# with a function:
public string GetData( )
return data; }
Where data can be up to 50000 characters. When I call this method in TestStand, the return value is limited to 256 characters in the string. Is there a setting to do?
Thank you
Alexandre Boyer
(3,178 Views)
Hi Alexandre,
I'm not aware of such a limitation. I just created a simple class that passed 435 characters to TestStand with no errors. Are you receiving an error message of some sort?
Test Engineer - CTA
(3,155 Views)
