Assignment in conditional expression
Shouldn't this work? I get a status error:unexpected token at the 2nd =:
True ? Locals.x = 1 : Locals.x = 2
Stephen
(7,821 Views)
Accepted by stephenb2
You need parenthesis: True ? (Locals.x = 1) : (Locals.x = 2)  Because it takes the first expression available.  In this case Locals.x was the first expression after the :  This means that it doesn't know how to evaluate the rest of the expression.
A better way to do this: Locals.x = (True ? 1 : 2)  Of course I understand your scenario might be slightly different and you were just using this as an example.  But I always try to move as much as I can outside of the conditional statement.
Hope this helps,
jigg
CTA, CLA
testeract.com
(7,818 Views)
Thanks, makes sense. Is multiple assignment possible?
True ? (Locals.x = 3, Locals.y = 4) : (Locals.x = 1, Locals.y = 5)
(7,810 Views)
Yes you can.
jigg
CTA, CLA
testeract.com
(7,808 Views)
