NI TestStand
Autostart sequence on UI launch
@Mr._Jim, this is basically how I also implemented the autostart feature (with the option to select execution entry point). I was closing the sequence file reference in the application shutdown state before, I tested to close it in the same place you did but the result is the same. I do have the LoadModules function in my code but that is disabled as it is causing the application to stop responding when executed (before the preloading modules dialog appears).
Message 11 of 11
(539 Views)
