NI TestStand
BNC 2110 keeps outputing 10.9V
Hello. I have a BNC 2110 block connected to a photo diode from the dev1/ai0 port.the output of the photo diode itself is varying over a new hundred mV, which is confirmed with an oscilloscope. However, when I connect it to BNC 2110, the output from BNC 2110 is always at 10.9V no matter how the light intensity on photo diode changes ( seen from the output in the test panel from NI MAX sofware). Is there a reason why the output might always be at 10.9 V?
(595 Views)
You might want to ask your question here : https://forums.ni.com/t5/Multifunction-DAQ/bd-p/250
and provide some more information like the settings you are using..... and how you power the photo diode
(574 Views)
Please share all details on the electrical connection and components involved. You shouldn't be seeing anything above +/-10V at the outputs.
Santhosh
Soliton Technologies
(570 Views)
