NI TestStand
Calibrator Fluke 5720A
Hello
I'm using a usb-gpib-hs to communicate with a Fluke 5720A through a self written code with pyVisa. I'm having trouble when i try to apply voltages above 22V, i'm able to put the voltage value in the calibrator, but i can't apply the operate command, the operate command takes the equipament off the standby mode.
Anybody has the ni-max command to test?
(546 Views)
I guess this is not necessarily the right forum to ask instrument related questions, is it?
(524 Views)
Correct. Sorry.
(487 Views)
